Im swapping a 302 into my Jeep YJ.. I have a C6 trans out of an early FS Bronco... and I have a starter motor based on that setup.. ( i told them it was for an early 80's bronco rather then a 92 stang to get a starter at Autozone...) Anyways.. im really confused about the wiring and the starter solenoid... The solenoid looks like a typical one.. that is two main posts opposite eachother on the bottom, and two smaller posts above.. where exactly am i supposed to attach the different wires from the mustang harness? and... theres a wire that comes out of my original Jeep bulkhead connector that is labled as "crank".. am i correct in assuming this is the wire that triggers the starter? or am i totally confused...
Also.. what is the absolute minimum wiring i need connected to have the engine turnover... on the mustang end.. its just that red/lt grn wire and red/lt blue wire.. then the two grounds.. the one by the 60-pin connector and the other is a black/ornge (i think) wire with a ring terminal and inline fuse at the end.... ??
shit anthother question...
In line fuses... now i didnt get both sides of the green connector by the 60-pin for the stang engine wiring harness.. and apparently on the other side were some fusible links that i need.. anyone know what the hell im talking about..
i hate fucking wiring
thanks
Shane
heres probably the worst fucking picture possible to show u what i mean.... paint is like drawing with god damn Crayons
http://www.people.virginia.edu/~smr7n/starter.bmp
btw ive been to EVERY site about these swaps... this particular question has not been answered (not even at http://www.bc4x4.com/chrisw/projects/powertrain/wiring.asp ).
thanks
Shane
