1 - 3 of 3 Posts
I need a little help wiring my friends CJ-7. Yesterday, his Jeep stoped running at a stoplight and wouldn't start again (click, click, click). I have check the usual culprits, battery, selonoid, starter, and they all seem fine. I load tested the battery and it tested out okay at 10.8 volts under draw. I'm not sure about the starter, but I was hoping that somebody would know where I could find a wiring diagram for a 1976 CJ-7 with the stock 6 cyl. Any help would be appreciated.
Thanks,
Kevin
Discussion Starter #2
Problem #1 is fixed, found a bare wire from PO's stereo install that was grounding.
Problem #2: for some reason now after shutdown, the engine continues to stumble for a few seconds. Any thoughts?
1 - 3 of 3 Posts
