1 - 8 of 8 Posts
Hey Guys,
Maybe someone can help me out with a problem. I have a 95 wrangler that i have owned since it was brand new. I just took the old 4.0 liter and started to do a chevy small block swap. I am almost done with it and have a problem, when I sold the 4.0 liter I also sold the main wire harness with it. The GM engine is a brand new crate engine from gm. It is also carbed. I need the main wiring block from inside the engine bay.I have all the other wiring that came from the factory. i just sold the main one with the fuel injected and the computer that came with the 4.0
Can anyone help me out here.
Thanks in advance
When i did my V-8 conversion i pulled the wiring out for the entire vehicle and started from scratch wiht a Painless 12 circut kit. It is much better than stock and worth every penny. I think they run about 300. Painless prolly sells just an engine harness too.
Discussion Starter #3
Yeah I will try that. Maybe that would work also. What did you do with the heater hoses. Meaining what did you use
Thanks in advance
You're in philly huh? My shop's 10 mins outside philadelphia. If you ever need help with anything, let me know. Check out the shop's website at www.hsoffroad.com , or give me a call. I have a bunch of old wiring harnesses lying around, I'm sure I can get you fixed up with something.
Hans
(484) 368-2929
The heater hoses are no big deal. . . i just got the correct size nipples and pit one in the intake andf one in the water pump. . . then made hoses to the heater core. 10 minute job, just buy the right size nipples to fit the same size hoses as the heater core of the jeep
1 - 8 of 8 Posts
