Hi folks,
I have a 96 f150 short bed pickup that did not come stock with dual tanks,
well I went down bought a tank wiring harness and all fuel lines out of a 96 f150 extended cab short bed pickup, cut the tank to fit and sealed mounted all the fuel lines and wires, i also cut the forward fuel door off the donor truck and mig welded that onto my pickup. everything fit like i thought it would which is great. however i am having some issues with my wiring. does anyone have an FSM in electronic format i could get ahold of. for some reason the new tank pumps for about 20 minutes then shuts off. also the rear tank just stops pumping sometime. so i would like to trace the stock wires as well as the new ones i have placed to try and track down the prob.
aditionally does anyone know if the pump runs on 12VDC or is it dropped down?
thanks!
thanks!
