1 - 19 of 19 Posts
Finally getting this much done,
This is mostly for the new adapter WMS is doing now, it replaces the stock 435 adapter for a much shorter one (2 1/4")
This is the prototype Casey and I worked out.
It should work for those of you considering a doubler but have limited wheelbase.
The assembly measured from front of transmission to centerline of rear output yoke is only 34"
Specs are: NP435 with 31 spline output (was cut shorter and resplined)
NP 203 with WMS 3.1:1 gearset
NP 205 with twinsticks set up on single lever.
Casey and WMS are kickass!
Discussion Starter · #2 ·
Closer look at the shifters
Different view showing off my paint job. :rolleyes:
High Angle will be taking care of the outputs. :D
Supergper said:
sweet...what do they charge for the doubler...is it the same or cheaper than the ord???
$750.00
The adapter is 3" long.
rusted said:
Ok, this may be a dumbass newb question but...
How much does that weigh? How much does an Atlas/Klune weigh?
I guess it's a moot point, you could put all that together for the $$$ of an Atlas alone, eh?
actually I am sure you could do a doubler w/o the extra gear set for much cheaper than the atlas and get the same results...but weight...I heard that they are pretty comparable but I dont have any #s for ya...
Discussion Starter · #16 ·
BillaVista said:
Doc,
yer starting to disgust me with coolness again :flipoff2:
Nice Chev orange paint on yer Ford drivetrain :flipoff2:
Hahaha, thanks Bill.
Bigbene was right about the flash, it's "tractor" red. :D
Discussion Starter · #17 · (Edited)
TRD, if you're referring to the 435 adapter, I'm sorry, I don't know what they charge for that.
Their # is (918) 341-1722.
The shipping weight on the palet was 424 lbs includes everything you see pictured. The downside is that yes, it's heavy.
I have just a little over 2K in everything shown. That's a grand total, including what I baught the transmission and T/C's for.
The 3.1:1 gearset is half of the total, it was $1000.
I have to say that Casey takes very good care of his customers even when if things go wrong and they're not his fault.
no strings on me
Very nice setup. I guess I need to save my 435 and 203 for a little later on....
I have talked to Casey about something similiar...he's very nice and helpful. WMS seems to be first class all the way.
Awesome setup...what's the rest of the story on the ride??
Discussion Starter · #19 ·
My ride?
Still have to finish front HP 60, Freshen up my Mustang 5.0 motor, get wheels and tires 18/39.5's and a few suspension parts and I'm ready to swap out the entire drivetrain.
1 - 19 of 19 Posts
