1 - 11 of 11 Posts
my TJ wont start. it was driving fine for the first part of the day. i parked uphill, turned it off; two minutes later it wont crank over. i checked the schrader valve on the fuel rail and nothing came out. so i am guessing the fuel pump went out. anything else it could be?
Discussion Starter #2
i wasnt that low on gas, so the fuel pickup should have reached despite the incline.
Discussion Starter #6
well knuckelhead, it wont start. the starter works just fine. there is not an inline filter. driving in the rain yesterday, didnt hit any puddles, but could it have just shorted out? it has been hard to start for a while, couple of months or so; was that my warning sign?
Discussion Starter #8
no. is there a way to check for the power and ground without dropping the tank? my Jeep is not here with me as of yet, and i am trying to research my problem before it gets here. thanks everyone.
Discussion Starter #9
so fuse number 21 keeps blowing. it blows when i turn the key to start it. thought that was my problem then it blew another fuse within a 20 trip...in the middle of the road no less. does this mean bad fuel pump? or bad wire splicing? bad ground? i see no bad wires anywhere.
sounds like the fuel pump.
Fuses blowing? What aftermarket electrical items have you done to cause this? Usually an electric aftermarket device of somesort spliced into the electrical system incorrectly can cause this. Or you just have plain bad luck.
But it really sounds like something is causing your fuel pump to a)fail or b) not kick on correctly. Go buy a chiltons manuel. they have high quality electrical schematics and how to chase down shorts in the system.
Good luck
Discussion Starter #11
bad luck you say? i always end up replacing engines sooner or later because they just seem to die. no real explanaition. the only aftermarket thing on there is daytime running lights, and also that 4.0L i swapped in to replace the 4 banger. it is a 98 model and i wouldnt doubt it is the pump. the jeep has worked great delivering mail everyday since january. january wasa when the swap took place. why now? it was working fine, then just quit...
1 - 11 of 11 Posts
