1 - 20 of 26 Posts
Ok, sorry to be misleading on the title and all :D but the po stripped the crap out of the fill plug on my rearend. It's pretty much round and it's on there really tight. I can't get it off so I was wondering what you guys would suggest. I'm also wondering if I can fill the diff through the breather hole? Sorry if this is too newbie a question, I wanted answers from the toyota pros :D and can't drive it until I figure it out. Thanks!
Filling from the vent's a PITA, weld a small bar to the fill plug, & turn it out.
Or sometimes a chisel & hammer work to spin it out.
You couldn't get something to weld to it or you don't have a welder?
*EDIT* We posted concurrently. Since you don't have a welder, what about using a cut-off wheel to make a slot in the plug, then turn out with a screwdriver?
I don't think getting it out from the inside would be any easier.
you can always weld a small piece of tube or rod to it, then you can get leverage on it.
Vice grips are another option
Sacrifice an old socket: get a socket that is too small and hammer it on there.... sometimes that works....
last resort: angle grinder - just be very careful!!!
when you are done, buy a bunch of the low profile drain plugs (offered by marlin, trail-gear, All Pro) and put them in the drain and fill spots. They are inexpensive and you won't have the same problem again.
I have stripped lots of fill and drain plugs. I have used craftsman bolt outs everytime. they work great, no welding. Just pound the bolt out on there with a hammer and hook up the impact.
You could try a pipe wrench. Normaly when the Vise grips just aren't enough the pipe wrench will dig in more, plus you can get them hooked up and beat on them with a hammer pretty well. I know it's a small surface, but if you are careful it should work. You have a tourch? Could try LIGHTLY heating the housing right around the plug. be careful with that though.
Cold chisel set against the flat and knock it around to "screw" it out...
PO did the same thing to the front axle on my truck... :shaking:
you could heat it a little, with a torch, even the heat from grinding a notch in it might do it. i would say crank down the vise grips though and use them, if you cant turn it with you arms stick it on there are use your foot to push on the vicegrips.
ive never strippes a fill plug, why cant people put a wrench on there straight? if a socket is seated right you wont have a problem, or if you cant hold a ratchet straight get a damn wrench.
Using an impact on a highly hardened material like a bolt out is a BAD IDEA. You are very likely to break the tool because it is extremely brittle.
Not to mention, the grabbing power of the socket is lost with inpact. It just helps strip it out more
air hammer :D Do it all the time at work... just make sure you have one with a nice trigger.
Wicked Raciest !
You know what causes this---12-point sockets, 12-point box end wrenches, opened end wrenches; Mexican socket sets (adjustable wrenches). Use only 6-point sockets and box end wrenches. Do not have any six-point sockets, go to HF and buy a set of impact sockets for about 10-15 dollars!!!!!!
1 - 20 of 26 Posts
