1 - 3 of 3 Posts
I need a Yota 8" rear axle out of anything 1986 or newer. All I need is a STRAIT HOUSING,a good 3rd member(with orginal bearing caps), and backing plates. I dont need gears, carrier, shafts, or brakes.
Perfer it to be in SoCal also...
[email protected]
Give me a call I think I got exactly what you need and I'm in so -cal. The only problem is the housing is set up for a coil sprung 4-runner so you'd have to cut/grind all the shyt off it and weld on some spring pads and shock mounts. Call me if your interested. 818-535-0131
sounds good, I'll give you a call after 5:00 today.
1 - 3 of 3 Posts
