1 - 1 of 1 Posts
The only time I have ever seen a different seal is on some newer housings that use a sleeve on the spindle and larger ID seal, remedy was to just remove the sleeve and run the 2081 rather than hunt for that elusive OEM seal.
But your problem is OD, I don't have data about the bearing hubs themselves so I don't know if it is even possible, but maybe someone put a different bearing hub on the axle all together. D60 maybe? :confused:
1 - 1 of 1 Posts
