21 - 25 of 25 Posts
I hope you used loctite on the case half bolts at least. Mine all backed out on my last truck. I caught it just in time.
So the teeth are fine but these little plates are broken. Nothing goes in between them, right? Any idea what they're called or where to get them?
https://imgur.com/lRsOOTh
Edit: looks like thrust blocks or preload dampers. Anyone know where to get a cheap set?
Edit 2: I'm seeing a lot of different part numbers online and three different part numbers for this over at justdifferentials.com. DET70760, DET70761, and DET70762. The ones in my locker look identical...they are the same part, right? Soooo I need two DET70760 for $24/each? I called them but they're closed.
that is the 'soft locker' shit that you need to remove to have it work properly in a front axle. dunno what you are using it in but I would throw those out
21 - 25 of 25 Posts
