WTS/WTT 85 Toyota linked 9" axles 40" stickies MUST GO!
I have owned it for 1 year just want something on/off road
1985 Toyota xtra cab/ built by Rick mooningham trick toys fab
115" wb
22re
23spline turbo trans
PSC full hydro single ended ram steering
Marlin 23 spline dual cases with stock front,and 23 spline 4.7 rear transfer case mounted disc e-brake
Front and rear and exo is 1.5" Dom
Front axle /is 3 link, spidertrax housing ford ball joint dana 60 knuckles ,wilwood rotors/ calipers high steer arms are double sheer, tru hi 9"hi pinion center section with nodular case 35 spline Detroit , 5:14 chromo 35spline inners branik Motorsports ,chromo 35spline outers branik Motorsport,with Yukon drive flanges 14" sway away coilovers
Rear axle/ is 4 link, trussed bronco 9" axle housing,35 spline Detroit in nodular case, new Dutchman chromo 35 spline axles, disc brakes, 16" sway away coilovers,5:14 gears
40" goodyear mtr stickies,17" polished walker evens headlock wheels 6x5.5 lug
Warn 8k high speed winch,with (12volt guy) in cab controller
Stock toyota gas tank mounted behind cab with alum. Tool Box mounted in back
Interior has 1 year old corbeau adj suspension seats,with sliders and back adjustment,wide version
Has new cd player Jl audio 6x9 speakers and 6" bazooka tube with alpine amp install 1year ago
Everything works heat,wipers,defrost etc.
I have breakall tube doors plus stock doors that fit in stock hinges both doors have quick release hinges
$17k obo or trade for built tj or lj on tons street legal / 4 seater rzr/built Tacoma/ Long travel 4door 4seater or something on/ off road worthy/ lets see what you think is worth mine don't waste my time with junk
Pm me with your email for pics or text me 530-414-3880
115" wb
22re
