1 - 10 of 10 Posts
Doing a X-over steering to my 79 chevy 1/2ton (with 1 ton axles)...i know that i need a 2wd steering box, but does it matter if the box is from a 3/4ton or 1/2ton??
A fucking killer
you'll need a 78 and later box, IIRC
the 77 and earlier use different fittings.
Thanks Zakk... i almost bought a 75 one off ebay
I also have this problem but my application is going on an 85 chevy 1/2 ton frame so what steering boxes should I be looking at?
A fucking killer
IIRC, 81 went to metric fittings, so 81-89
ideally, find a 2WD from the same year. that is what i did and there was no issues
I got a box off an older 2wd chevy, 77' maybe. For my 84' when i did x over, and the problem i ran into was My pump was O-ring style fittings and the box was a Flare fitting. i was able to do a little grinding and made it work, and nothing has leaked... But just to be safe, Like stated before get the box close to your same year....
be aware of the 77 split for input spline count as well
swapping steering boxes is not that easy unless you get the exact same year
They make an adapter fitting I found out.
1 - 10 of 10 Posts
