1 - 2 of 2 Posts
This kit is an Upper wishbone and lower arms. Good for around 6 inches of lift. From what ive seen this setup flex wicked good and it is BEEFY. The upper wishbone is solid tube. It needs new hiems on the upper bone the bolt size for Heims is 1/2 inch. FK part # JXT12T
You will need 3/4x3/4 12 TPI Heims with 1/2 misalignment spacers & you will be good to go. You will also need limit straps, see full droop pic. You will get a whole load of droop & need to limit it before the drive shaft binds.
Let me know if you have an questions. You will need to build one mount for the center of the axle which should be hard at all, just make it nice and beefy and the upper part of the wishbone mounts right to the stock upper mount location.
Price is $250 OBO and pick-up in Riverside is prefered, shipping will be alot cause the top mount is HEAVY.
The one center heim is almost brand new, and the bushings in the lower arms have only one trip out on them.
http://i171.photobucket.com/albums/u.../fulldroop.jpg
http://i171.photobucket.com/albums/u...r/Backview.jpg
http://i171.photobucket.com/albums/u...r/Sideshot.jpg
http://i171.photobucket.com/albums/u.../Frontshot.jpg
Thanks,
-Allen
PM or email me at [email protected]
1 - 2 of 2 Posts
