1 - 3 of 3 Posts
ok i was in a snow covered parking lot, and i went over a part where a plow had piled a little up, i went to back up and i couldnt go, so i put it in 4h and backed up, i edged back and then my wheels started spinning, then my front end started popping really loud and hopping. Now when i put in in 4wd and hit the gas, it pops really loud when it starts moving forward. Anyone have and helpful suggestions. '95 xj.........
Battle Masher
check the u joints(front) on the driveshaft and the axles(front)
Could be anything budd, you'll just have to take a look
1)U JOINTS BOTH AXLE AND DRIVELINE
2)TRANSFERCASE (PULL THE DRAIN PLUG CHECK FOR DEBRIS)
3)Pull the cover off the front diff, and inspect for broken pieces.
1 - 3 of 3 Posts
