1 - 11 of 11 Posts
ok will be out in 2-3 weeks
xj dana 30 hp w/ 4.56 gears and lockright locker.
Has tj axles in it w/ bigger u-joints and stockers as spares
one wheel bearing will need replaced soon (ie before you put it on)
explorer 8.8 w/ disks and 4.56 gears (believe factory l.s but will pop the cover when i pull this one)
Front is setup for a zj/xj/tj
Rear is setup for a zj w/ triagulated 4 link (trussed)
700 for both, right now dont want to split it up
Also
Rustys tie rod conversion steering for ZJ $75
Rubicon express i believe based on color 4.5" lift springs front and rear $100
Spring spacers will measure in the morning $20 a set
Shocks for 4.5" lift worn $10
33" mtrs on rockrawlers 5 x 4.5 pattern worn to probably 15% $150
spare new 33"at on new black crawler $75
I can get pictures of it all let me know if interested, prefer pm
do you have any interest in trading those axles toward a set of 5 40x13.50x16 procomp xterrains that are almost new?
1 - 11 of 11 Posts
