1 - 7 of 7 Posts
if its for the comanche in ur sig, they have the same springs as a xj stock, so measure them, and add about 4 inches to that, because RE usualy sits about 1 or 1.5 taller than it says if u dont have huge bumpers, and about right with advertized height with big bumpers and a winch/swing out tire carrier. sorry no #s to help tho.
XJack said:
If by under load you mean with 150lbs of winch and bumper a 2" coil spacer on it, I'll get it for you. Otherwise, no dice.
4" is fairly consistent for an RE 3" coil.
sound almost same setup as mine, i have 70mm spacer.
measure it for me? thanks
1 - 7 of 7 Posts
