ok the scoop is i was driving out to indiana, the tcase chain snapped hosing the tcase... got the rig taken apart , put a 4.3 atlas 2 in. now the trans has a slow leak that isnt coming from where the tcase bolts up to the trans.. its on the top somewhere put i can't find it. that isnt the real issue.. now mind you the trans was shifting PERFECTLY before this all started. now.. the trans will not shift out of 1st gear unless i gun it to 20 mph , let off the gas, then get back on it.. then it shifts thru the gears perfectly. if i stay on the gas it will just redline and not shift. so far i have tried replacing the tps, adjusted the vss, replaced one of the shift solenoids to no avail. no change at all. the only thing i have noticed is that the motor idles much better with the vss unplugged. HELP! i need to get the heep mobile and running right.
the running gear is a stock LT1 , 4l60e and atlas 2.
TIA for any help.
TIA for any help.
