1 - 12 of 12 Posts
1. Your steering box may be loose and might need to be rebuilt/replaced
2. Check your trac bar mount, steering linkages etc. in the front end to insure that everything is nice and tight. Also check the 3 bolts that hold the steering box to the unibody.
3. Check for cracks/breaks in the unibody where the steering box bolts on.
I replaced my steering box with a used one and i still had too much play in the steering wheel. So i went through the front end and noticed that the trac bar mount was loose. After tightening that up my steering is great and i havent had any problems since.
Jen, have a buddy turn the steering wheel while you watch the sector shaft, follow it down until you see the dead spot, whether it be the box, deflection in the pitman arm...I had the same problem once with a loose pitman arm nut, the arm was almost twisting / before it would move. Torqued it to spec and wala!
Hope that helps,
-Joe
what he said...to check the Trackbar for good joint stand beside the rig and look down at the tire.. if the body moves first the trackbar is toast, replace it
Since youl now be rebuilding or replacing your trac bar setup...
If you choose to just replace the bushing, or pickup another OEM tracbar.. Drill the axle and tracbar (where they meet) to 1/2" and replace that POS factory bolt with some gr8 hardware.
Discussion Starter · #9 ·
Good call, I was also going to move the track bar over a bit to halp correct some of mf suspension lift changes to the piece
move over the trac bar?.. you got any pics of your setup, if your not getting bumpsteer now, screwing with the trac bar can lead to problems unless your going with a well thoughtout setup.
Hey which jamboree you going to?
Discussion Starter · #12 ·
I need to do a fair bit of adjustment to the front end in general,... I am headed to the Jeep Jamboree in Rocky Mountain house, Alberta next weekend
1 - 12 of 12 Posts
