1 - 4 of 4 Posts
S
Guest
Hi all,
Has got someone bellhousing pattern for ZD30 engine in Patrol GU Y61?
Finally I decided to use Y61 parts for my project.
S
Guest
Discussion Starter #3
Hi.
I want connect gearbox from ZD30 to other engine. I'm not sure for this moment which engine I will use because I will have a lot of issues with space in my frame and front axle. I have few ideas for different engines.
I need bolt pattern of engine ZD30 or gearbox (this are the same dimmensions). Then I will try to make 3D simulation of adapter plate to connect this gearbox to other engine. On the end I will make probably twin disc clutch.
I need something like this (this is pattern for one of engine that I am thinking about):
1 - 4 of 4 Posts
