1 - 9 of 9 Posts
Yet another dilemma #@&^*
Thought everything was nice and cool putting my chassis back together. Installing my skid plate when I noticed something not quite right. Turns out my transfer outputs are about 1 1/2" out of parallel with the pumpkin(s) output. I did the Downey conversion per the instructions. Is this too far out of alingement? what affects will it have for the road? should I go back to the drawing board and get it to the nats ass? I've run out of holes on my motor mounts to go any further left. :(
If you are talking about L to R lateral alignment, it is no problem. I have seen people running a cuiser offset rear from a centered output NP205 with no ill effects. If you are talking about an angle mismatch between the two flanges, it may be a problem with vibration.
??? My two pumpkins run true to the frame (parallel) and the transfer is 1 1/2" over to the right line, parallel to the frame as well. ??? Hope this explains it a little better.
frame> _______________________________
pumkins>________________________________
__________transfer__________
frame>________________________________
Run it,
There should not be any issue with having the output off center by a tad bit..
I've run mine with about a 2" offset without ever any problems I wouldn't worry about it.
Moderating Midget
I built my rear axle 4" offset to deal with my 2F and Atlas combo.
When I went to the LT-1, I was centered and now the rear is 4" offset L/R.
It is not a problem since I only have a 7* angle up/down.
No CV, runs just fine, no vibs.
Discussion Starter · #9 ·
Great!!! That's music to my ears. Sure thought I f'ed up somewhere. It was a real concern for me since I will be using my Cruiser for the street also. Thanks a bunch for the info. :)
1 - 9 of 9 Posts
