1 - 20 of 20 Posts
this set-up doesn't use any spacers for the caliper and was designed to be installed on the same yoke as the drive shaft.....however on my truck it's too close to the oil pan in front and too close to the upper links on the rear :shaking: ( we designed them on a diff in the shop with truck at home) but they fit just fine on the other yoke also :)
Discussion Starter #8
you're too fast for me(resizing pics) :flipoff2: ..... what are you doing up this late
one little more request.. could u show how far away is the rotor from that axle
also how big are those rotor? 11 inch? or 13 inch?
Is that 1/2" plate?
Those are early toyota IFS calipers?
What machining did you have to do to the rotor to get it to seat against the flange?
How did you get the flange bolt holes perfectly?
Thankd Ross
yes its 1/2 yes they are from an 88 runner just opened the hole in the center up a little and he knows a good machinist
Discussion Starter #20
yea I would like to see what they look like mounted
1 - 20 of 20 Posts
