I have a 1994 yj born with a 2.5. I bought it originally with a 9 in in the rear and a 9/44 hybrid front axle with what I believe are cj front brakes. Before my coil over build the brakes worked ok. After sitting for 2 years I now cannot get my brake system to bleed well enough. my master was dry as I changed all the brake lines and wheel cylinders etc. Before I go buy a new master cylinder because I'm assuming it's bad from sitting dry so long does anyone have any input on if the 4 cylinder master cylinder is good enough for 37s. Or does there a trick to bleed the system or is it just that I need to bleed the master before I bleed the lines etc there is so much info online it's hard to know what to do first to trouble shoot.
Any help is appreciated
