1 - 6 of 6 Posts
92 4.0L YJ
I'm replacing my entire t-case (with an sye'd and cv'd unit) after last week's follies with bending the mainshaft etc.
Do i need to drop the entire tranny to pull the t-case (like it says in my haynes mannual)?
i have neither the tools or the know how.
after i unbolt the tranny mount and begin to unbolt the crossmember does the tranny need to be supported by something more than a small hydraulic jack?
how do i get the jack under the tranny and above the crossmember id it does need to be supported?
thanks
RJ
No U!!!!
Just remove the Case The Trans Has the Mount On it Correct Support the Trans Remove the Skid and Remove the Circular bolt's and The Shifter Attaching Point's and wham Oh its Out Remove the Inner boot that Cover's Shifter to Help Shifter Removal!!!Prior To Any Of this!! Come Awnn Common Sense
You Need
1 Friend Pretty Strong So if It fall's Throw it At Him he Will Know what To do!!
1 heavy Jack To Jack tran's or Stong Friend He Better have Good Medical though Check this First!!!
2, Pieces Of 4x4 Wood Six Inchs Long For Supporting Tran's With Jack Under Tran's or peice of steel So Jack can reach you 'r Shiat!!! Unless you are A low Rider
1, 3/4 Inch Wrench to Remove skid Plate And Little Torque Bar Attach to Trans Mount Don't Know What Size this Is Cause
(I have An Atlas!!! And Built My Own Skid So I dont Have this Crap)
1, 9/16 Wrench To remove Bolts Holding The Transfer case to the tran's
1,pry bar of some Sort to remove the Shifter Linkage From the Transfer Case,,, and remove Bolting Hardware And is Probaly One of the Many Bolt's Holding the Transfer case onto the Trans
1,And Some Help Removing the transfer case with Slight Pressure With Pry Bar As freind Help's You Keep Transfer Case Stable And Lower !!!!! Piece Of Cake Reverse Process to Install
wrench rating <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0">
About for Beers for Each Of You
Check Back Me next week For Dana 60 ???
This has Been Tech Talk By Adam Ant!!!
Any ?'s or Comment"s!!!! Blow me !!!
<IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0">
[ 09-25-2001: Message edited by: Adam Ant ]
Originally posted by Adam Ant:
<STRONG>9 1/6 Wrench To remove Bolts Holding The Transfer case to the tran's
</STRONG>
DAAAAAAAYUM Thats a BIG BOLT!!!
<IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0">
i have removed my d300 several times by myself. i imagine the aluminum cased 231 is lighter than my d300 but not sure. it was a bit heavy laying under the "heep" and letting it down and bench pressing it back up to put it back on but not bad. it might not be the easiest or the safest way but it works.
Originally posted by YDB:
<STRONG>DAAAAAAAYUM Thats a BIG BOLT!!!
<IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"></STRONG>
?'s Or Comment's
Blow Me!!!! <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0">
Originally posted by high5:
<STRONG>i have removed my d300 several times by myself. i imagine the aluminum cased 231 is lighter than my d300 but not sure.</STRONG>
Yeah, the 231 is quite a bit lighter. I did mine all by myself when I removed it to do my SYE.
It's pretty easy. Just support the tranny in front of the skidplate with a jack, remove the skidplate, drain the t-case, unplug all the shit from the T-case and disconnect the linkage, un-bolt the t-case, and then just get underneath it on a creeper and pull it off the pegs onto your chest. they only weigh about 100 lbs. (if that).
A monkey could do it.
HTH,
Jake Harsha
Hunt Technologies
Pequot Lakes, MN
1 - 6 of 6 Posts
