1 - 5 of 5 Posts
The gauge reards from about 5/8 of a tank to over full. What wire and where do I need to check the ohms to see if the sending unit is bad? or any other suggestions?
91 YJ with 2.5 4 cycl...15 gallon tank I think(takes 16 gallons?)
Any body have any suggestions for this? Mine is doing the same thing, can't seem to find any clear solutions after searching pirate.
The needle was on the F or past, it took 6 more gallons now the needle is laying in the the "only" area where it says "unleaded fuel only" (under the F).
Where should I start looking? If it's the ribbon wire to the gauge, can you buy those anywhere?
Any help would be greatly appreciated!
There is a connection toward the rear of the jeep that connects up the sending unit, these are the wires you need to ohm. You need to find a diagram that tells you exactly wich wires to ohm and the correct ohm range. Or you can pull the sending unit out of the tank hook up the mulit meter and move teh float back and forth for your ohm range.
1 - 5 of 5 Posts
