ok 92 yj 4.0l 5 speed
driving home from work i started hearing noise from the trans. sounded like birds chirping. so i pull over and there is a tiny pit of oil on the bottom of the bell houseing. (thats the last time it shows up) so i try to hear where its coming from and if i accelerate in 1st then let off the gas it makes a noise like break pads do if the rotor is warped and they are draging on and off. i change the fluid in the trans it wasnt low and did have a fair amount of water and dirt in it. drove it again being cold it made the noise more. the noise is like trire noise put pulses. the trans shifts better then ever with the new fluid. the motor mounts are great. (held break and let out clutch to torque the motor) when under the jeep you can hear the distinct noise coming from the bell housing (no fluid leaking) and there is no whistling
first guese is the slave cylinder/throw out bearing is going bad.
second guese is the fly wheel may be warped. (havnt driven threw puddles in over 3 weeks)
i want to think it is just needing the slave and clutch replaced. i replaced the master cylinder a few moths ago so i figured the slave would go soon. can some one confirm these sounds and my repair idea
