1 - 8 of 8 Posts
i got a 9" and i gotta get the yoke to match up to the u joints on my s10 so i can put it on. i dont really want to get a custom shaft or modify mine so does anyone know where i can get a yoke to match up to my s10 shaft? the s10 shaft uses bigger u joints than what the bronco yoke takes. what is involved with swapping yokes? is it just pullin that nut off the pinion, or is that gonna mess with gear backlash, etc??
i mite end up doin that. i would rather have a full u joint not one thats smaller on one half that seems kinda janky to me. but if its all that works then i guess itll do but id rather spend the $$ on a yoke that takes the s10 joint
I think you will be fine with the conversion joint, if you were in town I would swap it for $90 done balanced out the door.
actually the u joint on the front driveshaft of my truck fits into the yoke on the 9" but i know for sure that joint is smaller than the joint on the rear driveshaft. i figured it would be bigger too... neways how do i find out exactly what size the joint is?
1 - 8 of 8 Posts
