1 - 16 of 16 Posts
· Premium Member
Lowball said:
dont even reply if your going to tell me to search:flipoff2:
Newbie is, as newbie does...
You dont even need the *right* bracket per say... i did my york install using a bracket for a different style pump, possibly a sanden but not sure nor did i care since i already had my york. the bracket was very similiar except on top it had extra molding to hold the horizontal mounted pump. The bracket was off of 70s something AMC eagle wagon. All i did was cut of the protrusions and grind then down. take careful measurements drill holes and mount and your done... this is just in case you dont find the right bracket. if your interested or need i could take pictures..
TJ
I have seen a number of these setups on ebay. I have two different setups on amc v8s. The york was the factory a/c pump for the jeep, so it is a bolt on with the correct brackets. If using it for an OBA setup, make sure to check the numbers on the pump and get the larger of the available pumps to increase your output. There are at least three sizes available. All are available on ebay for pretty cheap if you look from ttime to time.
The York IS a bolt on on california 258s with the serpentine belts. It bolts directly to the bracket the idler pulley mounts to. Just remove the idler and replace with the york. You do need a sepentine clutch for the York.
Discussion Starter · #14 ·
If your factory bracket has an idler pulley installed and the idler uses 4 vertical bolts to mount it, the York compressor and serpentine clutch will be a direct bolt-in.
from the oba website...saweet
· Premium Member
Well if you had used some of that awesome brain power you claim to have, you would found out by now that Yorks were the fatory AC unit for AMC so that might answer your lame as newbie question... so wit that said...:flipoff2: :flipoff2: :flipoff2:
and merry fawking christmas too.
1 - 16 of 16 Posts
