1 - 20 of 21 Posts
Ok, I have one also...Can you adjust the pop off valve to POP at a different psi.? Mine pops at about 121psi, I've been afraid to jack with it...That sucker will scare the snot out of you when you tweaking on it!!
Discussion Starter · #9 ·
No, 3000 psi. Used to check accuracy of underground mine methane detectors.
The cylinders are 4"x12". They have the pressure regulators attached. I'm afraid the cylinder walls are so thick though that they won't do much good. I have to figure it out.
I need to find out the top end of the York psi because that would be the weak part of the system.
Hey, I could plumb a string of them with relief valves so that when I get hung, I could pop the valve and hop over the rock!
i have seen them hit 400 in a ac system but that is with a cool gas coming into them i think they would get two hot with air at 300# plus. mike
Originally posted by KYJ:
<STRONG>Run 'em in series, outlet of one into the inlet of the other, five or six of 'em setup like that ought to get you close to 3000 psi...</STRONG>
Stupid newbie shiat.
Between 300-400 psi max. It'll be screaming hot on the outlet side. Your cylinders can handle the max output easily.
Originally posted by Todd:
<STRONG>
[qb]Run 'em in series, outlet of one into the inlet of the other, five or six of 'em setup like that ought to get you close to 3000 psi...</STRONG>
Stupid newbie shiat.[/QB]
I apologize for my newbie response, but the point I was trying to make is that no single stage air compressor that I know of gets any where close to 3000 psi. My york loads down enough to slip the lose belt at around 150, where my pop-off also blows. Rather than fill your tanks with an OBA setup, take them to a gas supplier, and have them charged with CO2 or something closer to there design pressure, this would make better use of them than filling them to 100 psi or so, or get OBA, and a resonable (and lighter) tank. It'll work with the tanks you got, but it's like a f/r 60's behind a 4-cyl driven 31's, kinda overkill
The nice thing about the high pressure rated tanks is that the walls are 3/16 to 1/4 steel. It really comes in handy when you mount them under your frame just in case you hit a rock. I picked up a old scuba tank at the flea market for $25 and like it a whole lot better than my sun performance 125lb tank. Not only is the scuba tank heavy duty but it's covered in rubber, no rust...
Discussion Starter · #18 ·
Call me stupid, but I'm pretty sure that when Ranger replied with 300 psi, he meant that the York puts out 300 psi (that was your question right?).
<IMG SRC="smilies/blush2.gif" border="0"> And here I thought that he thought I put an extra 0 in. <IMG SRC="smilies/blush2.gif" border="0">
1988yj - that's why I got interested in them. Those things have to be able to take a hell of a whack.
1 - 20 of 21 Posts
