1 - 4 of 4 Posts
So I scored some craigslist gold tonight in the form of an unopened Yukon master install kit for an 8" 4cyl third ~$50. :smokin:
Now what I'm wondering is why does YUKON have two different part #'s for 8" 4cyl master install kits:
YK T8-A (14117) "Yukon Master Overhaul Kit for '85 and older Toyota 8.0 differential"
YK T8-B (14118) "Yukon Master Overhaul Kit for '86 and newer Toyota 8.0" differential"
It's not the V6, that has it's own kit (YK-TV6) I've got thirds from all years laying around the shop so using the kit won't be a problem, but I was operating under the belief that 79-95 (8") 4cyl thirds were all setup on the same bearings. Someone know EXACTLY why they (Yukon) have different kits?
Shit, nevermind, I found the answer: http://www.pirate4x4.com/forum/showpost.php?p=1478223&postcount=73
From Drew's post above:
"There are actually two types of R&P, let's call them "LPH" (Long Pinion Head) and "SPH" (Short Pinion Head)."
- '79-'85 rigs have SPH gears and a "thick" inner pinion bearing designed for the 4cyl housing. All aftermarket "4cyl" R&P and inner pinion bearings are identical to these factory parts, that way the same part numbers will fit all '79-'95 four-cylinder rigs.
- '86-'95 four-cylinder and V6 rigs ALL come with LPH gears. However, to use LPH gears in a four-cylinder housing you MUST use the "thin" '86-'95 factory Toyota four-cylinder inner pinion bearing. If you use a "thick" aftermarket bearing (or a factory '79-'85 bearing) the pinion will be too deep into the mesh and won't work."
So if I'm reading that right, I'm fine for putting aftermarket 5.29 gears into an '87 thirdmember using the YK Y8-A install kit that has the fat inner bearing because according to Drew's post "'79-'85 rigs have SPH gears and a "thick" inner pinion bearing designed for the 4cyl housing. All aftermarket "4cyl" R&P and inner pinion bearings are identical to these factory parts, that way the same part numbers will fit all '79-'95 four-cylinder rigs.
I guess the YK T8-B is for rebuilding using factory LPH gears on the 86-95 thrids? Is this correct or did I fawk up the reading of this?
You're correct. The -B kit is only for the '86 and up OEM pinions. If you have 5.29's, the -A kit is what you need.
1 - 4 of 4 Posts
