Almost ready for paint
Gotta wrap up this windshield restoration so I can get a top mounted and get back to working on the 3B project! Been busy with work, but got some time in the garage the last couple weekends...
Here's some pics of how it's coming together. I tacked the lower cross tube in place using the original front panel lower edge to set the tube position. The formed lower edge of the front panel was badly rusted out, with pits going all the way through the panel. I decided to replace that section with new metal. After tacking the lower cross-tube tube in position, I cut off the lower panel edge, and then finish welded the tube:
I then cut a center panel section, tacked it to the mating panel, and also plug welded it along the lower tube. This fixed the panel in place so that I could form the edge to the tube with a soft face mallet:
Then the lower corner patch panels were trimmed, fitted and tacked. (These were hammer formed previously). Here's one tacked to the panel and plug welded to the frame:
With the corners tacked in place, it was time for lots of little tacks moving around the panel with each one to avoid heat build up. Took a while! Ground them down, did a little hammer and dolly work to straighten out some minor warping, and then hit with a body file for first pass smoothing. On the interior side, access to smooth the welds is limited by the cross tube, but I was able to get it smoothed out reasonably running the grinder perpendicular to the weld - hitting it with the squared off side edge of a fresh angle grinder wheel.
Next up, I fitted the inside lower panel corners. I tried to mimic the original design, with the inside corner piece lower edge tucked into the front corner panel. There's a little cut out to clear the tube weld at the side, and another to clear the windshield clamp body. I'll weld these in later after the clamps are in final position.
Then I checked the fit on the body again. Tweaked the mounting arms about 1/8" side to side to get the frame centered to the body. The rolled curve of the lower tube I made fits the cowl pretty well, although not as good as I would have liked. The transition from the center arc to the clamp area is a little off so it bottoms out on the cowl at that spot first...so there's more gap at the center and at the side corners, but I think it will work OK. Better than the old 2A windshield - it's lower frame tube is rusted through and cracked at the clamp area so the clamps are primarily hanging on to the front panel sheet metal...which is cracking from the stress...
With the windshield frame centered on the body, I marked the clamp positions. I decided to make some small sleeves for the clamp mounting bolt holes out of some 3/8" OD stainless tubing I had around. These were faced and chamfered on the lathe and the ID bored a little to fit the 1/4" bolts. I figured these would keep the lower tube from flattening out from the bolt clamping pressure and keep water from making it's way into the lower cross tube through the clamp mounting holes. To position the sleeves for welding I threaded some screws through the clamps in reverse, and then clamped the whole assembly in place to tack at the front panel side first. Here's the holes drilled and chamfered in the front panel/tube, and the sleeves mounted on a windshield clamp ready to mount for welding:
Here's the front side welded and rough finished, as well as the backside tube welds - fully finished:
I have some POR15 on the way and I plan to paint the insides of the corner patch panels except for where the welds will be. Trying to keep them from rusting out like the originals did!
Fitting the vent door is next. It appears to be an aftermarket panel judging from the difference in paint colors removed. It is missing the latch on the door panel and the windshield frame is missing the spot welded "bent rod" bracket- a common malady as they tend to break off. Rather than replicating the original style bracket so it can break off again, I'll try to come up with a different design that's better supported.
Also, rather than using repro steel top mounting brackets spot welded above the windshield and along the inside sides of the frame, I'm going to use an aluminum extrusion I found. My CJ3B had an old Kayline top at one time and it used an aluminum extrusion that was screwed on. I found some "keter" rail that's a nice extrusion with the right size rope channel. It's width is a little wide, but I can easily cut that down. Keter rail is used for mounting signs, awnings, etc...I'm going to paint it to match the frame and just screw it on. I think this will work better than the original spot welded steel rails, which are rust prone. The steel surfaces that the rails mount to can be fully painted and the Al channel itself won't rust.
Once that stuff is done, then it's time for paint, mounting the glass, electric wipers and a new canvas Beechwood 3A top!
