pulled the front axle off and cut the front rear spring hangers off --front ones are still on, until I figure out what I'm going to do to the front--extend it with round tube or 2x4x3/16" or ÂĽ" after I cut the existing cobbled up stuff off and I'd like to position the front axle under it also. My brother bought the 3 link system so that's coming, so that will help to get that going.
I also started on the rear fuel tank placement with a ¼" diamond plate skid plate for protection, now we need to figure out if we really want to use the 50gal tank or not. At 13" tall, plus another 1 ⅜" for the bottom 90* fitting for total gravity feed and another 1 ¼" on the top for the return line spacing and some structural steel and it's getting up there in height and I'll have to raise the floor of the truck bed around 4". But this helps in fuel pump placement and hose routing. I can shave the 1 ⅜"- 1 ½" off the bottom by cutting a hole in the bottom of the skid plate and building a small skid plate for the gravity feed outlet. This will knock the truck bed floor raising to around 2 ½" , but I'm not sure I like the hose routing and fuel pump placement. Looking at a 20-22 gallon tank that's 11 ½" tall plus another 1 ½-2" on top for vent and return line. This will mean about a 1 ½"-2" truck bed floor raise. This would mean pretty decent fuel line hose routing and fuel pump placement. So really I don't think buying another tank makes sense. I just have to decide what to do. Another thing is the ground clearance at the tank will be around 29" if I do notch out the skid plate and around 31" if I don't, if I'm thinking correctly(I'll have to double check that tomorrow or Wednesday).
If I decide to keep the existing rear bumper I'm leaning heavily on raising it 4", which will keep it pretty close to the level of the fuel tank skid plate. Pretty much a no brainer in my eyes to raise it if I keep it.
Woke up this morning with doubts in my head about the 50 gal tank gravity feed location--may be on a junk yard hunt for something, but regardless I got more noggin scratching to do!!!
