FYI - hundreds of these have been installed in all walks of rigs; from mall crawlers, to hard core wheelers and not ONE failure to date!!!
Install is quick and easy!
1 year Warranty - no tire size restriction!
These don't use OEM thrust washers.
Made of 9310.
The pins are larger than other units.
There are only 4 springs and they fit inside the pins.
You assemble the entire driver assembly and then slip it in place and pull the release pins (See the side holes?) to release the springs.
Currently available for:
Dana 30, 27 spline
Dana 35, 27 spline - 1.6" Bore, 93 and Down
Dana 35, 27 spline - 1.5" Bore, 93 and up
Dana 44, 19 Spline
Dana 44, 30 spline
Dana 44HD, 30 spline
Dana 60, 30 spline
Dana 60, 35 spline
Ford 8.8, 31 Spline, 7/8" cross pin
Ford 9", 28 Spline
Ford 9", 31 Spline
GM 10 bolt, 28 Spline
GM 10 bolt, 30 Spline
GM 12 bolt, passenger and truck, 30 spline
Toyota 7.5", 27 Spline
Toyota 8", 30 Spline - 4 Cylinder
Toyota 8", 30 Spline - V6 and Turbo
Toyota LC, 30 Spline - 9.5"
Suzuki Samurai
Nissan Titan, 32 Spline
Open carriers only.
Other applications will follow later.
PM for quotes!
Here's a couple short vids of one of the rigs running the test D60 Spartan in the rear - with 39.5" Stickies.
Outlet Mall Bonus Line - YouTube
Outlet Mall Bonus Line 2 - YouTube
Made of 9310.
Dana 30, 27 spline
Dana 44, 19 Spline
Dana 44, 30 spline
Dana 60, 30 spline
Dana 60, 35 spline
Ford 9", 28 Spline
Ford 9", 31 Spline
Suzuki Samurai
Open carriers only.
PM for quotes!
