Guys i just got a stripped 82 cj7 tub. I am going to build it from the ground up. Someone told me a yj windshield frame will fit on it. Is it true? Also what about the tj or yj gate, will it fit?
In addition to the hold-down bolt holes not lining up, the YJ windshield frame won't have the holes in the bottom of the frame or at the bottom of the window for the CJ's defroster system.
Yes, the main heater box will swap in, but the OP asked if a YJ windshield frame would work on a CJ tub. My answer is correct - on the CJ, the defrost air is blown up through oval holes in the cowl and through the inside of the windshield frame. On the YJ, the defroster duct sits in front of the cowl and behind the dash, and the air does not go through the windshield frame.They are in the same spot? 79-95 had the same style heater system. 91-95 was a little different, but could still be swapped in. All the defroster holes will line up just fine from a CJ tub to a YJ frame.
I just took an 87 Wrangler tub apart and it was not the same as the CJ, so since 87 is the first year of the YJ I would say all years of the YJ were different from the CJ with respect to the defroster.I stand corrected. Were the early YJ's the same as the CJ's though? I had an 88 for parts and everything was the same if I remember correctly?
I initially made new plates for mine, but I decided I wanted to make everything stock CJ, so I instead moved the weld nut. They came out really easily, just put a wrench on it and twist. Then you can drill new holes in the right place and weld the same nut back in as I did.As far as the windshield frame lock tabs, it seams that the holes in the dash are offset about 1/4" or so. I am going to have to either make new plates or cut the the weld nut out of the tub and move it over to match the CJ parts.
