1 - 20 of 106 Posts
BigWoodyWag
Discussion starter · #1 · (Edited)
SOLD SOLD SOLD
Triple Nickel KOH/XRRA buggy
I'm relisting it back up for sale. It had sold but the deal fell through a week ago, based on the buyer not able to come up with the funds.
You can see this buggy on the opening to SpikeTV Xtreme4x4 "KOH Special" as well as on the KOH'09 DVD. Its had coverage in Crawl, Four Wheeler and several others.
For Sale, and ready to wheel!
2.5 seater (two adults, one kid), or ditch the rear seat for a LARGE "Go-Fast" BLADDER FUEL CELL (how it was originally configured)!
-Heavily Modified Rich Schmaus chassis
1.75” DOM main chassis
1.5” and 1.25” ancillary tubes
-GM L33 All-Alum LS1 5.3l
Jim’s Performance harness and flash
Manual Throttlebody
Kevco Oilpan
Remote Filter
Custom Catchcans for all fluids
Ron Davis Radiator
-TH350 standard Valvebody
-Atlas 3.8 (passenger drop)
-1410 Drivelines (front 2 piece has badass custom carrier that will NEVER explode)
-Custom retubed HP D60 front
4.88/Detroit/Superior shafts/Long’s
Mt. Logan Drive Flanges
Spidertrax Hubs
-Custom Narrowed Rear axle 14b
Vertical Limits Offroad shave
4.88/Detroit/Disc Brakes
-7075 tierod
-7075 Double Triangulated 4-link front and rear.
-1.75” links, except rear lowers are 2”
-1” Heims w/ 1” shank
-ORI struts
14” front
16” rear
Rebuilt, and modified with all of the Go-Fast updates (Oct '09)
-Steering
Howe TC pump, cooler, resi/filter.
HUGE lines (3/4” Suction on the supply line)
Front cylinder is PSC
-Brakes
Wilwood Master
CNC cutting brakes for L/R rear
Plumbed with Vinyl Lines (will stop on a dime)
-Winches
Front Warn 9R w/ Amsteel Blue Synthetic
Rear Warn RT30 w/ Amsteel Blue Synthetic
-Batteries
Dual Red Top Optimas
-Seating/Harnesses
Front Mastercraft Rubicons
3” Mastercraft 5-point Harnesses SFI Date of Manufacture March 2009
Rear MasterCraft MiniMe
2” Mastercraft 5-point Harness SFI Date of Manufacture May 2009
-Window Nets- Mastercraft
-13 gallon aluminum fuel cell
-17” Trailready HD w/ Champion Wheel lock rings
-39” BFG Red Label Crawlers 80%
-Roof is 1/8” Aluminum
-Hood/Grill is Chris Durham TJ painted heavy red metalflake, and vinyl stickered grill
-Skins are 16gauge aluminum
____________________________________________________________________________
For I'll include everything listed below, which is otherwise not included.
-Comm/Navigation
Kenwood Raceradio
PCI in-car communication
Federal Signal Siren, HORN, and PA.
All wiring and mount for Lowrance GPS (GPS not included)
1- Rear Shaft 14 bolt short side (works either side they are the same)
2- Chromo Stub Shafts
2- Chromo Short Sides
2- Chromo Long Sides (1 has slightly twisted splines)
2- 1.75" 7075 links with Heims.
1- Front driveshaft
Headlight VisionX LED (blinding bright)
Rocklights VisionX Tantrums
1- BRAND new Chris Durham TJ hood ready for your paint
1- 17" Trailready HD beadlock (spare)
1- Brand new (still has the tits on it) 39" BFG Red Label mounted on above listed HD
_________________________________________________________________________________
Make no mistake this is a used comp/trail rig, its not brand new, and it gets used fairly regularly.
Discussion starter · #2 ·
This is sitting just shy of full bump. I let the Nitro out on long road trips to get the buggy to tuck behind the racer box. Since I just came back from KOH thats 1600 miles for me of less drag.
Ride height is about 5"s taller in front, and 6"s in back.
Front 3/4
Rear 3/4
Controls
Front seats
Rear seat
heres a bump for ya Wyatt thats a steal!!!
Save
maybe trade???
would u be interrested in a 2003 F350 4x4 XLT-all power- reg cab,5.4 gas motor with 130,000 miles with factory 410 gears and factory posi trac locker in rear,35 bf's all terrains,excellent shape inside and out,flowmaster exhaust with k&n cold air intake system.,,,truck and 11,500 cash money,kelly blue book on truck is 13,500, thx if interested my # 678-481-4036
Discussion starter · #11 ·
Sorry I've got two Duramax's as it is. Don't need a third truck.
Wyatt, post up the motor specs.
I along with others where under the impression it was a pretty much stock l33but after seeing your post on jak it's far from it.
Jace
Discussion starter · #13 ·
Jace
Its nothing big, just warmed over after I bent a rod in Disney after the 1st Disney Challenge race where this buggy took 2nd by 30 seconds. Sucking the motor full of water @ WOT upside down in a 2 foot deep lake will do that. :laughing:
I dug around forever for the freaking cam card last night and receipt with the details thanks to the BJ proding he was giving me. I couldnt find any of it, so I just called the engine shop and asked this morning. TR220 lift cam (very mild) I think Dave told me makes the lift .550, stock crank, GM Performance rods and stock LS6 Springs from the dealer, Clevite bearings and Melling Hi-Flow Oilpump. He couldnt remember if he left the stock pistons or not, I think he did, he thinks he didn't and said they should be SRP's cause thats what they use for everything else. He said they cleaned up the heads but didnt hog them out. Also he's going to dig for the invoice if he gets a chance and get me a copy. I asked about the dyno sheet from break in and he said that the one he gave me was for the same motor they had done a few weeks prior. All the same parts. They broke mine in on a test stand not a dyno stand. That sheet said 398hp.
I've messed with the oil pump and thought the Melling wasnt working at one point and put a stock one back on it (turns out bad guage). Jabnasty ended up with the Melling on his. Jab ended up replacing mine but it ended up on DSI's buggy for KOH'10. I have since put a Melling back on, when I had the oilpan off to fix a leak back by the remote leads.
Aside from the guage issue I had a themostat stick once, and had to swap that out. Didnt get over 230 though.
Buggy fully gets it, and will light 'em off. Motor is throaty but nothing radical.
Discussion starter · #16 ·
Pics dont do it justice, but to do justice to the pics they suck! Cloudy, windy, crappy day, crappy camara, and a semi clean car equal crap on the pics.
TTT
Discussion starter · #19 ·
Thanks Nolen, and Bones.
Its a damn good car, we've had a lot of fun with it. It goes just about anywhere, and can do just about anything, it even rolls over on command :homer:
I've heard it pulls to the right really bad. :flipoff2:
Oh yeah, It will put you in front of everyone for a race if you can drive.:flipoff2:
Good luck with the sale.
Save
1 - 20 of 106 Posts
You have insufficient privileges to reply here.
