SOLD : 1986 CJ7 (Crawler w/Kingpin, 14Bolt, Propane)
Start @ $15,357.33
Trades or Partial Trade for Trailer Must be 7.5ft wide and long enough for Jeeps. Prefer Aluminum but would take Steel as long as it's modern, like 2006 or newer with LEDs and such. i JUST traded for this. Only reason I'm selling, I'm a JK guy (my job requires it) and with a little guy the rig on here I'm interested in has a back seat.
1986 CJ7
~104" wheelbase
~86" outside Tire : outside Tire
~85" tall
42" Pit Bull Rockers
H1 Recentered BeadLock Wheels with PVC Inserts
350 Engine
Turbo 400 Automatic
205 Twin Stick-case/ Clocked
Propane Fuel/MSD/ Optima
PSC Hydro Steering
Ramsey 15k w/Synthetic Winch
King Pin60 Front/DiscBrakes
14 Bolt Rear Rotated/Disc Brakes
welded 4:88 gears Fr/Rr
Suspension/Body:
CJ7 Springs, have spare 2-YJ Shackles to convert if it interest you
Rust Free YJ Tub with proper Rolled Fenders not cut, rear is comp/cut and boxed for tail lamps
Proper CJ Dash Install all Functional Controls-Defrost,Heat, Headlights, power outlet (New Speedo Cable to Be installed, that is why Trans Skid is off)
Proper CJ Windshield with Functional Wipers and custom covers over motors
Proper CJ Tail Gate Added Functional Latch and tailgate stops
CB and Radio in water proof container/Marine Speakers
5point Corbeau Belts OttoR Buckets Seats
Full Cage inner-Sleeved and welded, even french cut into floor to optimize headroom
Body is line-x truck bed coated inside & out along bottom edge.
Custom Made Top that retains factory front channel and loops and velcros around bars for a snug fit, also snaps to door upper frames from inside, as well as the floor. It's a truck style cab simply because the propane tanks are layed down. They could easily be cut into the floor with a seat on top, or installed vertical.
Propane tanks or Fork Lift Tanks, they can be filled anywhere.
Satin Black Paint-it's not spray bombed flat black.
Pictures: http://photobucket.com/CJ7propane
TwoFourEight-207.Eight1Sixtythree
CJ7 Crawler on Propane - YouTube
Start @ $15,357.33
1986 CJ7
~104" wheelbase
~85" tall
350 Engine
Turbo 400 Automatic
PSC Hydro Steering
Suspension/Body:
