F250 HP44 to Wagoneer Width......Lots of Pics
I know it's been covered MANY times and is nothing new but it never hurts to have an extra example.....
Step one: Grind through the weld, if you think you're through give it a couple whacks with a big hammer and see if you can see a crack form (a flashlight helps to see the crack).....
The crack will be VERY faint at first, as shown in this picture.....
From there, heat really helps speed up the process, but you really just have to beat if off the tube from there.
With the knuckle off, you want to precisely measure and mark how much of the tube you are removing. I based my measurements off of Mr. N's website using (REMEMBER: THIS IS TO CUT THE HIGH PINION FORD F250 TO A DRIVERSIDE DROP WAGONEER WIDTH):
For the stock Ford shafts:
34.75" for the long side inner shaft
18.62" for the short side inner shaft
For the stock Wagoneer shafts:
32.12" for the long side inner shaft
15.80" for the short side inner shaft
The difference between the two which is what need to be removed is:
2.63" on the long side
2.82" on the short side
