Okay guys. I just finished up my YJ build and now I'm bored with nothing to do. So what I found was an old Postal Jeep - '83 DJ-5 Mail Jeep in okay condition. Runs but tranny is bad. Clean title. So here is my plan. I photoshoped what I want the jeep to look like. My inspiration is the build that Marsfab in NC did called "Mild CJ5 Build". If you haven't seen it you should check it out!
My mockup...I am a graphic designer so I had to see what it would look like. I like drawing pretty pictures. i hijacked marsfab's cj5 with their cool jeep wall art. I photoshoped my jeep with the CJ-5 that marsfab built since the wheelbase and specs will be really close to that cj-5.
my inspiration for this build is here. Marsfab is a local shop that does excellent work on any type of 4wd. This CJ-5 is bad ass!
http://www.nc4x4.com/forums/showthread.php?t=94675
My goal: #1 to build a fun weekend wheeler that seats 2 and can be beaten up with little worry. #2 build it CHEAP! but still dependable. #3 build something i've never seen before.
Plan is to use a Jeep Wrangler 6cylinder, 5spd and NP231 transfer case with all the computer and wiring from whatever model I find (anyone got one they wana sell cheap?)
Final Drivetrain Choice: '01 5.3L LM7 w/ 130k miles, SM465 granny 4spd & NP231 w/ 2wd low.
axles & gearing:
the owner is throwing in a full width ford 9" rear so that is what the rear will consist of. i'll add a spool and run 5.38s probably
front axle: i gota hp44 full width front from a '76 f-150. spool or cheap locker and 5.38s.
Final Axles & Gearing Choice: (Rear) full width ford 9" w/ 5.14 gears, spool and ford 8.8 rear disc brake homebrew conversion. (Front) '76 Ford F150 High Pinion Dana 44 w/ 5.13 gears, Auburn Pro LSD diff & matching 5.13 gears, Chevy 10 bolt/dana 44 knuckles and spindles for left side flattop high steer arm, rebuilt axle as needed.
suspension:
front: SOA with factory rear DJ-5 2.5" springs, relocate and outboard the front hangers to get the extra wheelbase and space to mount the steering box.
rear: SOA with shackles attached to custom built rear bumper using XJ leafs.
Final Suspension Choice: (front) SOA w/ YJ 5-leaf packs (will eventually add extra main leaf), Shackle reversal and 2nd hand gas shocks. (rear) SOA w/ XJ springs flipped, will add durango or ranger extra main leaf because the springs are already sagging, cheapo gas shocks outboarded for extra stability.
steering:
switch to left hand steer unless i can find a right hand wrangler steering box. anyone got one?
flattop knuckles and high steer with tie rod ends.
Final Steering Choice: Ended up keeping the jeep Right Hand Drive with a 2wd Chevy Saginaw steering box w/ custom built pitman arm, 3/4" heim joints and crossover style steering flipped for RHD. Custom steering box mount on outside Right Hand side of framerail.
wheels and tires:
37"-39.5" tires. either iroks, pitbull rockers or maxxis creepy crawlers...whatever i can find the best price on. wheels will be cheap steelies or used beadlocks.
Final Wheel/Tire Choice: 36x13.50x15 Irok Bias Ply tires w/ cheap black steel wheels.
Other additions/changes (that are screwing up my "budget build" : Full Interior Custom cage, Custom rear corner armor, rock sliders, rear cage tied to floor in at least 6 points, Custom bumpers, All new floors, Custom fuel cell mount, Custom motor mounts, etc, etc.
right now i'm gathering parts, scraping and cleaning everything i can so i can get off to a good start and building the suspension.
the cool thing about the mail jeeps is they have a partially boxed early cj-5 frame. they have an 81.5" wheelbase which is the same as early CJ5s and I've just never seem one built so I figured I'd give it a shot.
axles & gearing:
suspension:
steering:
wheels and tires:
