'79 toy 4x4 with an '85 EFI motor. Motor was rebuilt about 5 years ago and only has about 30k on it. also it has an '85 EFI Tranny and Tcase and all the '85 drive shafts. it also has front and rear axles out of an '85. all the gears are stock. the truck runs great but the check engine light is on for some reason. al the wiring has been done to fit the 79 dash so everything works. no leaks in the driveline. power steering, good brakes, good clutch, runs cool. it has the normal small exhaust leak. the body is really staight but it does have some small dings and dents. it also has the larger 17 gallon gas tank from an '88 toy. there is no lift although i have lifted shackles and toy rear springs and an IFS box you can have with it for a little extra $$. the front windshield is only a few months old. oh the tires are 33 x 12.50 swamper tsl's on 15 x 8 aluminum directionals. 2 of the tires have about 80 % and 2 are bald. it also comes with a spare 33 allterrain. the paint is new but it is some wierd 70's or 80's paint job that was on it when i got the body. it still needs a few little odds and ends but the main things that it needs is to be smogged and i am sick of working on it so my loss is your gain. this is a great running truck that could easily drive home, and would be a great wheeler. if you want pics i can email them tonight. im asking $1600 obo. thanks
***BUY THIS TRUCK AND GET 10% OFF A DOUBLE T-CASE SUTUP AT INCHWORM***
Rob
Rob
