1 - 7 of 7 Posts
RockSolidPerformance
These are New gear sets and Master overhaul kit combos for variauos Axles.
DANA 60 High or Low Pinion Any Avalible Ratio Gears and Master Overhaul Kit-$300.00
DANA 70 Any Avalible Ratio Gears and Master Overhaul Kit-$370.00
DANA 80 Any Avalible Ratio Gears and Master Overhaul Kit-$355.00
DANA 44 REAR Standard Rotation Any Avalible Ratio Gears and Master Overhaul Kit-$260.00
DANA 44 FRONT Standard Rotation Any Avalible Ratio Gears and Master Overhaul Kit-$265.00
DANA 44 FRONT Reverse Rotation Any Avalible Ratio Gears and Master Overhaul Kit-$305.00
DANA 44 JK Rubicon Front Any Avalible Ratio Gears and Master Overhaul Kit-$345.00
DANA 44 JK Rubicon Rear Any Avalible Ratio Gears and Master Overhaul Kit-$360.00
DANA 44 TJ Rubicon Front Any Avalible Ratio Gears and Master Overhaul Kit-$295.00
DANA 44 TJ Rubicon Rear Any Avalible Ratio Gears and Master Overhaul Kit-$295.00
Dana 30 Standard Rotation Any Avalible Ratio Gears and Master Overhaul Kit-$230.00
Dana 30 Reverse Ratation Any Avalible Ratio Gears and Master Overhaul Kit-$265.00
Model 35 Rear Any Avalible Ratio Gears and Master Overhaul Kit-$215.00
GM 14 Bolt Any Avalible Ratio Gears and Master Overhaul Kit-$320.00
Some Combos may vary for unusal aplications. All prices without tax and shipping. For questions and other pricing Call 616-696-8114 Or visit rocksolidperformance.com
Free shiping Now thru 3-31-13 Handling fees still apply
Ford D44 amd GM 14 bolt
I want 4.88 gears for HP Dana 44 and GM 14, but i have a question concerning the GM 14 gears fitting on a stock carrier or do i need to buy a spool.
Thank You
Rory Jensen
1 - 7 of 7 Posts
