I am from TheRangerStation forum and they all suggested I come post here as well to get some more advice but I am wanting to start here soon building my 1986 Bronco II from a daily driver to a rock crawler.
This is what I started with:
This is what I got now:
So right now I am looking at the D44 SAS for the front and the 9" rear end for the rear. I have seen some of the other B2s have stretched the wheel base out to 98" so I might try and tackle that while I am swapping the axles. I also want to do a dual t-case to get the lower gears. I will likely keep the 2.9 and the FM145 transmission just do a rebuild on both while I got them out. I just have some questions about the axles and the t-cases.
As far as the axles, I believe to get the straight axle dana 44 I need to look for a 70-79 Ford F-150/Bronco? And the TTB dana 44 is F-150/Bronco that is later than that? Is one better than the other? Anyone know of any good write ups on the d44 sas in a early model bronco II/ranger? I have briefly searched but the ones I found really didnt get specific on the list of parts they need for the install and the modifications need to install it.
Second, Do the transfer cases have to be different to work together? I have heard of people mating the 1350 and the 1354 but could you mate a 1350 and a 1350? Would you still get the same affect?
This is going to be my first build so I am going to be asking a lot of questions and the most detailed write ups are appreciated. I am having to pull a lot of my resources to get this build complete but hopefully it will be successful and 2015 I will be wheeling either The Rubicon Trail or MOAB! Be easy on me fellows this is my first build so I will ask a lot of dumb questions.
