I have my rock crawler for sale. Asking $12,000 and pretty firm on that. Started life as a 93 s15 jimmy and over the past couple of years has turned into what I have now. It has a 4.3 v6, 700r4 and a brand new atlas 4.3 with heavy duty input and output shafts. New front and rear drive shafts with 1350 joints. Dana 60 front axle with 5.38 gears and spool, alloy USA axle shafts and g2 drive flanges. Rear axle is a 14 bolt with welded carrier also has disc brakes with bluetorch fab caliper brackets and new calipers. Has four link front and rear suspension with fox coil overs in front and bilstein coil overs in rear. All heims are QA1 1 1/4 and all links are 2 inch 250 wall. It has corbeau seats front and rear with harnesses. New RCI fuel cell and new Holley fuel pump. LED lighting. Tires are 43 tsl sx with weld on beadlocks. Steering is psc full hydraulic with 2.5 double ended ram. Any questions just text me at 830-two 75-three 238
Would be interested in trades for one ton TJ
Rock crawler
Rock crawler
