1 - 16 of 16 Posts
Seabass
· Premium Member
Every time I pull my Honda eu2000i out the carb seems to be fubared from shitty fuel. Next time I pull the carb off to clean it I'd like to install a dual fuel kit. Looking for a good kit to purchase. You guys have any input?
Nothing to add about this, but on both of my father's 2000s he cut in a fuel shutoff in the line. Its a little hard to get to since everythings sealed up, but really only takes 10 minutes to run the carbs dry and put them up for storage
Discussion starter · #3 ·
I've read about that and it sounds like a good start but the tank gets nasty as well. Definitely couldn't hurt. I hate this ethanol junk we got at the pump.
A few of the hot dog and halal vendors in NYC run them..They seem to like them compared to the additives you gotta run in todays fuel..
Even with the fuel valve, the carb needs to be drained prior to storage.
A fuel valve does make it easier to winterize, as you dont really have to drain the fuel tank. Just toss some stabil in it, top the tank off, and cap it.
Im currently in the market for a tr-fuel kit. Seems to be the ideal setup for me.
Run on natural gas at home for power backup
Run on propane for the camper
And run on gas when I dont have NG or LP close.
Biggest problem I see is that it voids any and all Honda warantys. No real biggy though, as these little EU2ks are so damn dependable.
Discussion starter · #10 ·
As far as I know there is no ethanol free fuel here. If it is available it's not convenient enough for me.
i just run my generator dry after using it. Then i dont have to mess with any additives, i just fill the tank up when i want it and 2 pull later its running.
thats what I do on my EU3000is honda. If I wont be using it for a while I let it run out. The 3000 has a metal gas tank and the 2000 I bet has a plastic tank. I am a firm believer in plastic tanks reacting with fuel causes trouble. I see it in atvs every day.
I just converted my eu2000i to propane. I was tired of cleaning out the carb every six months because of it gumming up.
I purchased the kit from Generator Conversion Kits to Propane and Natural Gas.. With shipping it was $200. Motor-snorkel kit, tri fuel.
The hardest part of installation was mounting the vacuum regulator to the generator side. Careful marking and drilling made for a great installation.
I've used it for about 8 hours since the conversion. Works great.
How does the price of fuel consumption between the LP vs. Gasoline compare?
Typically propane is about the same per BTU as gasoline.
Nat gas is so much cheaper but currently hard to find. It's available in both liquid and compressed gas depending on where you are at. Cleaner, cheaper, readily available as a fuel, just not quite to the main stage on distribution.
Clean energy has both liquid and CNG stations nation wide.
http://www.cleanenergyfuels.com
1 - 16 of 16 Posts
