My lead fab guy is selling his 4runner.
This was built in house, and the fabwork is spot on. He is my lead fab guy and this thing is built right.
For Sale: Addicted Offroad Built 96 4Runner Crawler/Daily/Expedition Rig. 2 year long build, and not a single inch was left untouched. A 100% stock 4Runner was turned into this with the best parts, knowledge and skills used to build it.
1996 4runner SR5, 213,xxx miles, 3.4l V6, A340e Automatic, 25" frame height on 37's, runs like new on the highway at 80mph or on the trail under 1mph.
Suspension:
Trail Gear Tacoma Kit C
3" Leaf Springs
Frenched Rear Shackle Mount
5125 Bilstein Shocks
Front Frame Reinforcement Plates
Tacoma High Steer Kit
Six Shooter Knuckles
ARP Knuckle Studs
86-88 IFS steering box
T100 Oil Pan
Power steering hose conversion kit
Axles:
Rock Assault Front Axle Housing
Longfield 30 Spline Chromoly Birfield/Axle Kit
Rock Assault Rear Axle Housing
4340 Chromoly Rear Tacoma Axle Shafts
High Pinion 3rd's With 5.29 Grears
Front/Rear ARB Air Lockers
Aisin Manual Locking Hubs
Rear disc brake conversion
Wheels/Tires/Brakes:
37X12.50R17LT Maxxis Trepadors 70% tread left
Pro Comp 98 Rock Crawler 17x9 Wheels 2.5" Backspace
V6 Calipers & Vented Rotors up front
DriveTrain:
23 Spline 2.28 Input Gear
Trail Creeper Tacoma Dual T-Case Adapter Kit
95 4Runner Speedometer Sensor
HD front and rear CV Driveshafts. Front is a long travel shaft
Transgo A340 Race Valve Body
Hayden Transmission Cooler
Armor/Recovery:
Rock Defense Tacoma Dual T-Case Crossmember
Addicted Offroad One-Off Plate Front Bumper with hidden winch/rocklights and lightbar
Addicted Offroad 68" Heavy Duty Sliders
Addicted Offroad Custom "Lambo" Rear Tire Carrier
Lil 'Skips Offroad Gas Tank Skid
Smittybilt XRC8 Comp Winch w/ Synthetic Rope
1st Gen 4Runner Roll Bar for storage and mounting
Lighting:
2002 4Runner Clear Housing Headlights
FX-R Bi-Xenon HID Projector Retrofit w 5000k Bulbs
Dual Row Flood/Spot 22" LED Light bar
CREE Led Reverse Bulbs
7- 10w LED Rock Lights (Super Bright)
LED Interior and Dash Lighting
Performance:
Original 5VZFE Motor, fresh gaskets including head gaskets.
We inspected the motor while it was torn down. There is still cross hatching in the cylinder walls. This motor will do another 100-200K easy with proper maintenance.
Timing belt, water pump, pulleys, tensioner done at 203,000
Newly Installed TRD Gen 2 Supercharger
New Genuine TRD Supra Fuel Injectors
TRD FMU
URD Pulley (extras Included)
Full 3" Stainless steel Exhaust
Cold Air Intake with upgraded 99+ MAF
Tacoma Radiator
AEM Wideband o2 Sensor and gauge
Walbro 255hp In Tank Fuel Pump
Glowshift Trans Temp and Boost Gauges
Elecronics:
Pioneer 3300BT DVD Headunit - Bluetooth Calling, DVD, Sat, USB, SD, Ipod etc.
Rearview/nightvision Backup Camera
Cobra 75wx CB Radio
Pioneer Speakers and Tweeters
JL Audio 12" Woofer w 1000w Pioneer Amp
Other:
6 CFM OnBoardAir setup with 5 gallon Reserve tank. Can run air tools with this setup.
Dedicated ARB Air Compressor for the Lockers
In cab and wireless winch control
An array of 4x4 Rocker Switches
Husky Catch all mats
This rig doesn't need anything to wheel just about any trail in the country. The light bar needs to be rewired in, and the on board needs to be wired back up. That is it.
$16,900 FIRM. This is a steal given the parts list and that everything has less than 10K on it, and its rarely even been wheeled since being built.
Serious inquiries only. No tire kickers.
Suspension:
3" Leaf Springs
ARP Knuckle Studs
T100 Oil Pan
Axles:
DriveTrain:
Armor/Recovery:
Lighting:
Performance:
TRD FMU
Tacoma Radiator
Elecronics:
Cobra 75wx CB Radio
Other:
