In the last few months it seems we have not been selling nearly as many gears, lockers, and Install kits that are not going in a custom axles. We can do about any custom axle and have the parts available to do them, but we have an enormous amount of Gears Lockers and Install kits in our wharehouse in NC. Which means there is no middle man, a tracking # can be provided on the spot, and accurate ship times are met.
We specialize in Offoad parts so our inventory is this: whats listed is absolutely in stock at all times unless there is a complete national backorder and we will buy out other vendors to insure we have it
GM 14 bolt:
All ratio 14 bolt from 3.73 through 5.38T
All master install kits no matter year
Mini Spool
Full Spool
Detroit Locker
Grizzly Locker
ARB - RD114
1350 u-Bolt Yokes
Dana 60:
All ratios from 3.55-538 Both regular rotation and Standard rotation
Master install kits
King pin Kits w/ a Tool to remove
Wheel Bearing Kits front and rear
Spools - 3 series, 4 series 30 and 35 spline
Warn Hubs
Drive flanges
All chromo axle shafts
Ujoints- Spicer 806x and 300m Joints
Detroits 3 series and 4 series
ARB's
Lockrights
Spindles
Spindles Bearings
ARP studs
Spindle Nuts to hold wheel bearing
Spindle studs and nuts
Dana 44:
All Ratios Thick and Thin reverse and non
All master install kits HD, D44a, Rubicon, JK, front and rear
All axle shaft Kits- front and rear - need custom blanks ready to be splined
Spindle bearings
Spindle Nuts
Grizzly lockers
Lockrights
Spartans
Warn Hubs
Spools
Carriers
Spider gears
Dana 30:
All ratios TJ, High Pinion, CJ, ZJ,
All master kits
All axle shafts- 30 spline no problem
ARB
Detroit
Spartan
Carrier
Ford 8.8:
All ratio's
Master install kit
Adapter flanges 1310/ 1330
1350 yoke
TJ weld on brackets
ZJ weld on brackets
YJ weld on brackets
TJ ebrake cables
Brakes We got 8.8 brakes
Lockrights
Detroits
Mini spools
Full spools
Rear shafts
C-clip eliminator kits
Clutch pack rebuild kits
Toyota 8", 8" V6, T100, 8"clamshel, 7.5 clamshell, landcrusier:We ship assembled 3rds w/ 5 year warranties
Every gear ratio
all master kits
All yokes
ARB
Detroits
Spartan
Lockrights
Axle shafts rears, front mini's fj 40, 60 , 80's
These are the biggest sellers and what we do the most of in house. If price is the issue call me well match and beat anything thats not losing money. all these parts are in stock and we install daily so you need tech support not a problem I have 2 installers plus myself that see stuff day in and day out.
Warranties we handle all the warranty claims on products we sell unless other wise mentioned. We can touch the stuff we sell and ship same day if ordered before 4pm eastern standard, On the west coast thats fine we have small wharehouse on the west coast that has many of the same products but not the qty and can still ship you parts with 2-3 days max no matter where you are in the country. And we use USPS for smalller packages that can ship cross country in 2 days.
Its hard for us to answer all posts in threads, much better at PM's and even better at email where we can provide you with a detailed exact estimate that is saved so if your not ready to order you can call back with the estimate # when you are ready. Or even better Call us we answer the phone 8am-6:30PM Mon-Fri. And communicate via email on the weekends chase@eastcoastgearsupply.com
919-672-2705
GM 14 bolt:
Mini Spool
Full Spool
Detroit Locker
Grizzly Locker
ARB - RD114
1350 u-Bolt Yokes
Dana 60:
Master install kits
Warn Hubs
Drive flanges
ARB's
Lockrights
Spindles
Spindles Bearings
ARP studs
Dana 44:
Spindle bearings
Spindle Nuts
Grizzly lockers
Lockrights
Spartans
Warn Hubs
Spools
Carriers
Spider gears
Dana 30:
All master kits
ARB
Detroit
Spartan
Carrier
Ford 8.8:
All ratio's
Master install kit
1350 yoke
TJ weld on brackets
ZJ weld on brackets
YJ weld on brackets
TJ ebrake cables
Lockrights
Detroits
Mini spools
Full spools
Rear shafts
Every gear ratio
all master kits
All yokes
ARB
Detroits
Spartan
Lockrights
919-672-2705
