1 - 11 of 11 Posts
Tass
Unimog 404 axles, narrowed 7.5", pinion coversions, 7.56 gears, cable lockers, high steer plates, all brackets for hydro steering and links. spare brake parts, plus 5 Hummer beadlocks with 3/8" plate centers (Mog pattern), 3.5" BS. Ready to bolt in for $3750,
Tass
Save
Look in his sig. line link
Save
Discussion starter · #5 ·
They weigh somewhere around 1100lbs together. Just to clarify, the WEPS high steer plates are not installed. I'm still using the stock arms flipped over with a 3/8" wall DOM tie rod.
Tass
Save
Discussion starter · #7 ·
BurnedBronco said:
whats wheel moutn width, plus what side was narrowed and how much?
thanks
WMS to WMS is 61" The front axle was narrowed 7.5" on the driver's side to put the diff over to the driver's side as much as possible, The rear was narrowed 7.5" on the pass. side so the diff is centered.
Tass
Save
1 - 11 of 11 Posts
You have insufficient privileges to reply here.
