1 - 9 of 9 Posts
Fl-Krawler
Discussion starter · #1 · (Edited)
built 88 YJ near tampa Fl. clear title. all parts on the jeep are less than 4 months old it has the following: engine cage, 10 pt roll cage with seat mounts built in, brand new mastercraft desert camo pattern seats,RCI 15 gallon fuel cell, new auto meter gauges (tach,speedo,oil pres., tranny temp,volts, water temp, and fuel) custom BTF alum. dash, B&M mega shifter, currie twin stick, PSC full hydo steering using BTF hi-steer arms, 4 wheelers supply rock crawler hood, ramsey 8000# winch with sythetic winch rope, the engine is a fresh tuned port injected chevy small block, fresh 700r4 tranny, both of which are controlled by a new howell efi harness, D300 transfer case, heavy walled 1350 long travel driveshafts,BTF full width front axle kit/shackle reversal, stock YJ front springs with 2 extra main leafs, BTF YJ2XJ rear kit with stock XJ springs, Cody's offroad traction bar,front axle is a fully rebuilt chevy kingpin 60 with new 5.13's and a detroit locker.the rear axle is a disc braked 14 bolt with new 5.13's and a detroit locker as well. the jeep also recieved a new painless jeep harness during the build up.it rolls on 39.5x18x15 boggers on 15x10 TR beadlocks . $16000 obo.. only trades i will consider are for similarly buit TJ's or a stock TJ and some $$$ i will not part it out.. link to pics comming soon
Discussion starter · #5 ·
i built the cage myself( i run a small time fab shop) you can follow the links of look in the Yj section of the www.floridajeepers.net forums for pics of it being built... i built it back in Jan. so you would need to look under that time frame... the entire cage is built out of 1.75" and 1.5" .120" wall DOM
This is a sick rig. I just drove it over the weekend and you just point and go with it. Drives on the street just fine and seems unstoppable offroad. All the fab work is nice and tight, and he's a great guy to deal with. I wish I could of made it work for me. Somebody should check this out, they will be happy.
1 - 9 of 9 Posts
You have insufficient privileges to reply here.
