I'm looking for a donor for a V8 swap into my 85 FJ60 Land Cruiser.
The drivetrain need s to end up w/ a NP203 transfer case. This is going to be modified as a doubler in front of my stock LC split case.
So, the question is...
What 85 or newer GM small block and auto trans would be the most common and easiest to source?
What trannies were factory w/ the 203? What truck has the simplest set up?
I like the idea of TBI injection, so that would put the donor vehicle 87 or newer, yes?
I believe the donor motor has to be 85 or newer to pass emmisions in AZ.
Sorry for the broad questions, I'm trying to narrow down the field when I hit the bone yard/auto trader.
Thanks in advance!
Thanks in advance!
