1 - 16 of 16 Posts
sdwaigle
Discussion starter · #1 · (Edited)
I have a 2001 tj straight title, black with tan top
-54,000 miles straight title 10k loan value
- 4 cylinder, 5 speed, 4.88 gears, speedo dead on with 35's
-HP non disconect 30 front out of cherokee
-Claton long arm kit front with 5 inch coils
-dorango steering box with X-factor HD high steering kit
-8.8 rear axle 31 spline disks
-Rear leaf xj suspension stretched 10 inches
-Poision spider tube fenders and rear compcut with rock guard quarters
-SYE and 1 inch motor mount lift
-AIR CONDITIONING that works great
-10 gallon Aluminum fuel cell that uses stock pump and gauge works correct
-This has been my DD while I was fixing my truck, I got 17+ mpg, no squeaks rattle , driveline vibrations and steers and drives better than stock.
$8500 Call 1-517-403-5569 pics coming soon
Discussion starter · #3 ·
That pic is the rear tri link arms from claton and the spring perches are already moved back, you just need to tab the axle and add coils and it is a full claton kit. the brackets are for the frame, the axle housing also goes with sale it is a rubi 44 the jeeps outers will work just add carrier and shafts I dont have time to and the 30 works fine. The tires are xterrain 35x12.5x17 with 1.75 spacers the tires are 80+% tread.
Discussion starter · #6 ·
Yes I got the jeep a month ago and have been driving it while I was fixing my truck, I have a 98 that is more of a milder trail rig and I wanted to make this a extreme rock crawler, I already had the rear arms and front housing, I wanted to lock it, but time and exrta money for toys are short now so I will just run my 98 tj which is stock wb and short arm for now and pull the winch cable a bit more on the hills, It is a great jeep but I can only afford one.
1 - 16 of 16 Posts
You have insufficient privileges to reply here.
