my 76 f150 build.. flex shots page 6
ok, here's the deal.. I have a 76 f150 4x4 the I cut the bed off of & shortened almost 2 feet. I'm in the process of 3-linking the rear & puting stock xj coils on instead of leafs (too stiff w/ no weight in the back). then I remembered I had some pro comp MX6 shocks laying around that are pressurized to 300psi.
here is the question!! do you think the shocks alone will hold up the weight of the rear of the vehicle without having to use springs??
thanx
jason
thanx
jason
