So, I decided to build a new front end a couple of years ago when my Dana 30 came up bent housing (imagine that.) I'd been collecting parts for the better part of a year and finally started doing some actual work on the thing a little over a year ago. Just finished the hydraulics for the steering two weeks ago.
The first purchase for the project was a pair of end forgings I found on craigslist. One had about 4 inches of tube and the other had a good sixteen inches still in it. I paid $100 for the pair.
The tube had to be extracted from the end forgings so I could turn the ends down an eighth. The Dana 60 tube is 3 1/8" and the Currie housing center I bought accepts three inch tube for four inches. So after cutting the tube as close to the end forging as I could and then grinding out the weld as much as I felt comfortable with. I cut the tube with a sawzall and knocked the chunks out until the whole end forging was devoid of tube. It took three cuts altogether per tube.
Here are pictures for the first section. The second section removed was about 100 degrees around the circumference. As I would pound on the section of tube with hammer and chisel, I would grind a little more of the weld away each time. This way I removed as little material as possible from the end forging. The things are so hefty, I probably could have just ground the hell out of them in the first place but whatever.
